Throttle Tolerance Programming Mode
Description: This mode allows the user to program throttle tolerance and effectively pair a PCM and
pedal. When a new PCM or pedal has been installed, the previous values stored in the PCM may not
match the specific tolerance of the pedal and need to be reprogrammed.
Notes: This mode requires simultaneous inputs from a user on the throttle pedal as well as the
multifunction light stalk. When programming, follow the steps in a deliberate, but not rushed, manner.
2/5/2009 Page 6 of 10 AEV30200AA
The entire process should take approximately 3-4 seconds. If the process is completed either too fast or
too slow, the pairing will fail.
Procedure: Consult the Quick Reference Guide and set the DIP switches accordingly. With the engine off
and ignition on, plug the module into the OBD port and follow the steps below:
1. When the module is ready, the Electronic Throttle (ETC) Indicator (a lightning bolt surrounded by
two vertical lines) will flash on the dash.
2. To start the pedal routine, pull the headlight stalk back into the “Highbeam Flash” position, then
release the headlight stalk allowing it to fall back into the “Highbeam Off” position. The routine
has now started.
3. Press and hold the pedal all the way to the floor.
4. Move the headlight stalk forward to the “Highbeam On” position.
5. Release the pedal completely.
6. Move the headlight stalk back to the ”Highbeam Off” position.
7. The routine is now completed.
8. Turn the ignition Off, wait, then start the engine. Test the pedal and verify that it is functioning
properly. If not, repeat steps 2-8.
