может есть у кого картинка со шлангами и направлением циркуляции жидкостей по системе охлаждения на дизеле?
Сверху вниз, как везде.
От термостата еще идут два шланга на охлаждение егр и печку.
на джека у меня нет... есть из описания мотора 2,8 KJ...
на джека есть чтиво
OPERATION
When engine is cold the thermostat is closed. The cooling system has no flow through the radiator. The coolant flows through the engine, water pump, and heater.
When engine is warm, the thermostat is full open. The coolant flows through the engine, radiator, heater, and water pump.
On the diesel engine coolant flows through the engine, radiator, heater, and water pump.
As coolant expands, some coolant will move to the coolant recovery container. Once the coolant cools, the coolant from the coolant recovery container will move back to the radiator. (Gas engine only)
в воцап пиши и скину фотку
