FORD Sport Trac Adrenalin Package
Летом 2008 года товарищ успел притащить из Штатов и растаможить по вменяемой цене (таможенники такой видели впервой) такой вот пикапчик на базе Ford Explorer - Sport Trac в самой заряженной комплектации - ADRENALIN, с моторчиком 4.6. Чуть прокатившись на нём - я понял, что он оправдывает название комплектации.
Вот данные производителя на авто 2009-го модельного ряда:
Exterior Dimensions
Wheelbase (in.) 130.5
Length (in.) 210.2
Height - empty (in.) 72.5
Width (in.) without mirrors 73.7
Width (in.) with mirrors 84.8
Track width - front/rear (in.) 60.8/61.8
Minimum running ground clearance (in.) 8.4
Cargo Box Dimensions
Length - at floor (in.) 49.6
Width - between wheelhouses (in.) 45
Height (in.) 21.2
Cargo box volume (cu. ft.) 37.5
Interior Dimensions
Head room - front/rear (in.) 39.8/38.5
Shoulder room - front/rear (in.) 59.0/58.9
Hip room - front/rear (in.) 55.4/55.5
Leg room - front/rear (in.) 42.4/36.9
Capacities: Passengers, Luggage, Fuel
Seating capacity 5
Interior cargo volume - behind front seat with rear seat backs folded (cu. ft.) 44.4
Fuel capacity (gal.) 22.5
Engine Specifications
Drive type Four-wheel drive / All-wheel drive (opt)
Engine type 4.6L SOHC 3V V8
Transmission 6-speed automatic
Final drive ratio 3.55
Fuel economy 15 city / 21 hwy
Horsepower (SAE net@rpm) 292 @ 5700
Torque ( lb.-ft@rpm) 315 @ 4000
Compression ratio 9.8:1
Valve lifters Hydraulic roller
Fuel delivery Sequential multi-port electronic fuel injection
Exhaust Single, stainless steel
Engine block type Сast Iron
Cylinder head material Aluminum alloy
Chassis Specifications
Front suspension Independent short- and long-arm, coil-over-shock w/stabilizer bar
Front shocks Gas charged
Rear suspension Independent trailing blade short-and-long arm, coil-over-shock
Rear shocks Gas charged
Brakes Power 4-wheel disc with anti-lock system
Steering Variable assist power rack & pinion
Maximum Towing Capabilities – Conventional Towing
Maximum Towing Capabilities – Standard (Class II)
Engine:4.6;Axle:4x4; Ratio:3.55; GCWR (Lbs.):8500;Max Trailer Tow (lbs): 3500;Max Payload (lbs):1390
